Will this amp/sub combo work together?
You will have a 1.5 ohm load not 1. The amp does 1200 at one so they may see about 1000 maybe 500watts per speaker which should be a perfect match. I believe the 12w6s are 500 watts rms each. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
the bp1200.1 does 1200 at 2. It also does 1200 at 1, it just runs under higher stress. 1.5 is better than 1 -- and with only 300w subs you should be able to run the gain REAL low which will help keep the amp happy.
scooter2479
scooter2479
Macon,Mo
scooter2479
