Will the plane take off?? Finally going to be answered.***
  • Total voters
    92
tiger bass you REFUSE to accept the fact that you are iggnorant about how the forces involved interact.
the plane will take off
you seem to think that the plane is coupled directly to the treadmill like a car. when the plane is in fact coupled only in relation. the forward trust applied to a plane is not in relation to the ground, it is in relation to the air. this is where you seem to get confused. because there is a big difference between true and relative groundspeed. and true and realative airspeed. you would know this if you were a pilot
the fact that the treadmill is under the plane makes no difference to the forward trust applied by the planes engine. the treadmill goud be moving at 10x the groundspeed of the plane and the plane would still gain speed. everyone that says the plane won't move because the velocity = 0 is iggnorant to the fact that the plane is not directly coupled to the ground like a car is.. a plane does not need the ground to gain speed. just the air.
ground speed is irelavant to air speed
yup that's right. a planes ground speed doesn't matter only its air speed. this is why in theory if you had a steady 200mph headwind you could have a plane lift of the ground without having any forward volocity in relation to the ground
so to anyone that has no flying experience:
air speed is irelavant to ground speed
air sped is what matters
ground speed doesn't mean squat
Ok thats great thanks for the information, BUT there will be NO airspeed. The prop on the plane is used to pull the plane forward not to throw air at the wings. Therefore the plane starts moving forward but the conveyor makes it not move at all. Ground doesn't matter but there is 0 airspeed because the plan is not moving. Plane does not take off.
ya you failed to grasp the whole way a plane uses thrust, the trust is not coupled directly to the ground (like a car) it is coupled to the air. once you grasp this very simple concept you will realize how ignorrant you are
you said right in your post the prop on the plane is used to move the plane forward and it will do just that. and it will gain airspeed do to the thrust produced which will over come the minimal drag the wheels have.
the fact that the ground is moving is whats throwing everyone off, when in reality the ground speed really doesnt matter bacause the trust is not applied through it but only in relation to it
you could use an airboat in the same theoretical example altho the drag forces involved are greater between the boat bottom and water surface
now that I think about it. the plane will probably fly
Reason for changing my mind it that i kept thinking of the planes wheels as being in gear, when in actuality they would be more like in neutral so no matter how fast the treadmil goes it will just spin the wheels on the plan as the plane is moving forward.
Chevillac
The X Factor
Chevillac
international
AllStar1500bd
