Will my amp see a 2 ohm load?
Here is what I will be doing, on each side of the car will be 1 tweet and 1 mid, plugged into 1 crossover. thats 2 tweets, 2 mids, and 2 crossovers. the left channel of my amp will go to 1 crossover, which goes to 1 tweet and 1 mid, same with the right channel. What I want to know is if each individual speaker is 4 ohms, my amp will run at 2 ohms right? I just want to make sure that my amp will see 2 ohms, because my amp does 160x2 at 2 ohms, but it only does 80x2 at 4 ohms, and I would need something better if it saw 4 ohms.
Ahh I found the answer:
No. Since you would wire one "pair" (crossover, tweeter and mid) to each channel, each channel would be running at a 4ohm load. The only time the final impedence changes is when you are actually wiring the speakers together (either in series or in parallel). Since you aren't doing that with comp sets, each channel will simply "see" the impedence of the speakers connected directly to it.
Bummer, looks like I'll need something that does 150x2 @ 4 ohms.
Do you mean get two mono amps that do 150 watts at 4 ohms, one amp for each door?
edit: wait thats not what you mean, hang on i'll look up bi-amping.
yupitsabuick
yupitsabuick
Mi
yupitsabuick
