Will Kicker L7s work with this amp?
on1yalad
LA
I am unsure what my amp can handle and i dont understand the ohm thing enough to make an educated decision.
The 2 subs i have included in this thread come in a Dual 2ohm impedance or a Dual 4 ohm impedance. So what sub should i get for this amp i listen to hip hop and drum and bass?
Lastly what is the difference between the subs? and what is a single, dual, quad coil mean in terms of powering?
Alpine PDX-5
http://www.crutchfield.com/S-Df9bFnsS9uq/App/Product/Item/Main.aspx?I=500PDX5
08VS12L72
12" Solobaric L7 Sub Box - Vented 2-ohm
08VS12L74
12" Solobaric L7 Sub Box - Vented 4-ohm
if your intending on spending $600 for that amp, I'd do a little more research
Back on topic, go with a single channel amplifier, commonly known as Class D mono amps, for subwoofer usage. As for coils, it's just a different number of coils to give a wider range of wiring options to acheive certain ohm loads.
you're better off looking at an L5 if you want to match power output with handling. Of course 300watts to the L7 wouldn't hurt it.
300watts to an L7 would hurt you.....people would make fun of you if they know what they are talkin about....so for the fact that that doesnt happen.....i want u to get a better amp try a mono channel or 2 channel....then pick the subs......always build around an amp.....itll sound best that way....but consider your budget
How would it hurt it? Are you stupid? Under powering a sub WILL NEVER HURT A SUB, EVER.
oh...really...are...you...sure?
how so?
****....i knew that was gonna catch alot of people after i posted it.....
it may not sound best unless u have the best box.....but u will have better power ratings than trying to push an L7 on 300watts
I get a a huge discount on all things kicker, and i figured that the L7 would be my best buy.
Code:
Removed discount prices
08DS12L7 12" Solobaric Dual L7 Sub Box - Vented 2-ohm or 4-ohm $ 999.95
08VS12L7 12" Solobaric L7 Sub Box - Vented 2-ohm or 4-ohm $ 549.95
08VS10L7 10" Solobaric L7 Sub Box - Vented 2-ohm or 4-ohm $ 499.95
08TS10L7 10" Solobaric L7 Sub Box - Vented, Thin Profile 2-ohm or 4-ohm $ 449.95
08DS12L5 12" Solobaric Dual L5 Sub Box - Vented 2-ohm or 4-ohm $ 799.95
08DS10L5 10" Solobaric Dual L5 Sub Box - Vented 2-ohm or 4-ohm $ 699.95
08VS12L5 12" Solobaric Single L5 Sub Box - Vented 2-ohm or 4-ohm $ 449.95
08TS10L5 10" Solobaric L5 Sub Box - Vented, Thin Profile 2-ohm or 4-ohm $ 349.95
07S18X Solo X 18" DVC Subwoofer 2-ohm or 4-ohm per coil $ 1,599.95
07S18XSP Solo X 18" Replacement SPAIR 2-ohm or 4-ohm per coil $ 349.95
07S12X Solo X 12" DVC Subwoofer 2-ohm or 4-ohm per coil $ 1,299.95
07S12XSP Solo X 12" Replacement SPAIR 2-ohm or 4-ohm per coil $ 249.95
07S10X Solo X 10" DVC Subwoofer 2-ohm or 4-ohm per coil $ 1,199.95
07S10XSP Solo X 10" Replacement SPAIR 2-ohm or 4-ohm per coil $ 229.95
I really don't plan on buying another amp right now. i have a 15 year old pair of 10's that thump but my amp is too powerful for them so i thought about movign up a little bit.
if i did i would buy a Alpine PDX-1.600 (but i wanted a single 5 channel amp for space reasons) 499.99 kinda pricey considering i paid extra for a 5 channel
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=120&i=500PDX1600&tp=115
If the L7s aren't right for this amp what kicker sub would be (please include model number)?
get yourself a solox
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif i don't really need that much, what do you think my best option is for a 367watt 2/4 ohm amp would be out of the list?
Could my amp power the L7 decently? i could always later upgrade. It looks like the L&s RMS is 750 for 12" and 600 fro 10" i am coming up about half would that be enough?
Here are some other options i have.
Code:
06VCVX12 12" Solobaric CVX Sub Box - Vented 2-ohm or 4-ohm $ 499.95
06VCVX10 10" Solobaric CVX Sub Box - Vented 2-ohm or 4-ohm $ 449.95
06TCVX10 10" Solobaric CVX Sub Box - Vented, Thin Profile 2-ohm or 4-ohm $ 399.95
07DCVR12 12" Dual Comp VR Sub Box - Vented 2-ohm or 4-ohm $ 449.95
07DCVR10 10" Dual Comp VR Sub Box - Vented 2-ohm or 4-ohm $ 399.95
07VCVR15 15" Single Comp VR Sub Box - Vented 2-ohm or 4-ohm $ 399.95
07VCVR12 12" Single Comp VR Sub Box - Vented 2-ohm or 4-ohm $ 299.95
07TCVT12 12" Single Comp VT Sub Box - Sealed, Thin Profile 2-ohm or 4-ohm $ 299.95
07TCVT10 10" Single Comp VT Sub Box - Sealed, Thin Profile 2-ohm or 4-ohm $ 279.95
I have only ever owned a 10" is there better sound with 12"?
on1yalad
on1yalad
LA
on1yalad
