Will JBL 600.1 Run 2 Alpine Type R's?
  • 2
I wasnt sure, I know most times if you have a amp too small running bigger speakers, the amp will cut out. So If I run the Type R's at 2 Ohm (Giving them the suggested 300 RMS each) The amp will not have a problem with these?
u will get 300rms a piece at 2 ohms. an amp to small will not cut out. the only time it will is if it has protection cuz of some idiot turning the boost and gain all the way up.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
980
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
5K
thewoahna
thewoahna
Cleveland Area
kottonmouth
    May 12, 2024
Brendon Jenness
    May 11, 2024
