will it fit
Max_Power
^ From a Hairdryer ^
This is a really stupid question, but I still have to ask it. I am going to be doing a "truck box" install soon, and need to know if my box is deep enough to fit some subs. The box is going to be a trapazoid (sp?) box with these dimensions.
Box Width: 50"
Box Height: 12"
Box Top Depth: 4"
Box Bottom Depth: 6"
This is what I was trying to explain, NOTE: disreguard the port, this box is to be sealed!!! (The link does not fill in the requried dimensions you must)
http://reaudio.com/speaker_box/LPort_Box_Calc.html
The woofer's diameter is 10" and 4.75" deep, and are really close to fitting I know. I was playing with my CAD program for at least 50min, trying to figure it out.
Please tell me if the woofer is going to clear the back of the enclosure! This was poorly explained I know, ask questions to be accurate!
Thank you, for the last week I was wondering if I should order the subs. This will be going into a standard cab ranger, and will fit behind the seat. I was wondering if there is a minimum distance that the subs have to be away from somethign inorder to sound ok. I relize they should touch something because of mechanical reasons, but I thought if it didn't quite fit right that I could get 1/4" spacer between the baffle and the sub to help slightly.
Any light on the sub breathing room would be great. So please chime in......//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Max_Power
Max_Power
Toledo, Ohio
Max_Power
