i actually wear a full body suit...its custom and protects me from everything
I see you are learning.....congratsc'mon kskitka i know you know the answer lol
gracias dmanfor your wire question, as long as you do not exceed the wire's potential, you can split it as many times as you want
I gotta peethink of it like water flowing down a river. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
//content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gifI just go in my depends.
instead of running another 0ga run how about a 4 way distro block?if your not getting dimming, you should be alright without upgrading your alt. If you decide to run a real amp later on then you might need to upgrade it then. I dont see you having issues with another amp. but you Might. The big 3 would help.
also dont split it like that. Just get another 0 gauge run or something neater. dont put more current draw on a wire that cant draw the power from a larger one.
I ran 1/0 to the rear, and then a distro out to my amps....the easiest way and IMO best way of doing itinstead of running another 0ga run how about a 4 way distro block?
0ga in 3 4ga out?
thanks man!
