Will I need a battery for this setup?
The Big Three won't help you much if you plan to listen with the engine off for extended periods of time. In that case, a deep cycle battery is the only way to go...
But I would recommend both a HO alternator if the stock one isn't up to par and an extra deep cycle battery.
if primarily listening with engine running just do the "big 3" and you should be fine...thats unless your running a 60 amp alt.. you'll be fine
i have a 1500 rms amp and a 1000 rms amp...i get slight dimming...barely noticable
with
135a alt and a 900cca batt
halfbakedalaskn
halfbakedalaskn
Icy version of Hell
halfbakedalaskn
BP1Fanatic
BP1Fanatic
