Why pay more for a JL audio amp?
Power isn't Power, all amps certainly don't sound the same (different manufacturer's use different designs and topologies) if you think they do you are tone deaf or just plain can't tell the difference.
If you can't tell a Class D amplifier from a Class A/B amplifier then it probably does not matter what you use. Buy the cheapest made crap you can find with 10% THD and 50db S/N Ratio and Channel Separation because power is power right.
Dampening factor determines how well an amplifier controls the drivers connected to it, how quickly it starts and stops. It also makes a difference at what specific frequency that specification was measured at. The Orion XTR-100/NT 100 has a dampening factor of 1000 so even if loaded down to 1 ohm it still has incredible control. If you are listening to a double kick drum being pounded repeatedly your amp should be able to keep the woofers moving accurately to reproduce the notes as they were recorded not as a jumbled horrid one note mess.
If you can't hear the difference between an amp like an Orion NT 100 and a Jensen maybe you should stick with an iPod and a pair of earbuds.
Flame away little biatches.
maybe you will learn something from this thread..
now i dont know about you but i cannot hear the difference of 1/1000th of a second. you are misinformed. any damping factor of 50 and above is perfectly comparable of any other above 50. the differences are statistically and realistically negligible.
anyone who says otherwise, like you, is simply misinformed by the marketing of competing companies.
it's 3% THD.
Really .5% THD in the midrange frequencies would likely be audible with test tones if someone had decent hearing (specifically the reason why test tones are not allowed in RC's amp challenge). So it's not really "inaudible".
Distortion is simply much harder to identify with music due to a wide multitude of factors.
I guess my hearing a distinct difference between the two amps (one with a lower, and one with a higher DF) was a fig newton of my imagination. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
livinlegend
livinlegend
grand rapids, mi
helotaxi
