The 1500 is way more durable and better built/designed . It will handle loads under 1 ohm no problem and last. The SAE-1200D is a great budget amp and does great at 1 ohm nominal but it doesn't really like to be played continuously below that. As far as better parts I don't think there is any huge differences in the quality of the actual semiconductors in either of these amps as even the SAE-1200D uses International Rectifier and Fairchild Semi in the power supply and output section respectively which are darn good parts. One huge difference between them though is actual build quality as in how they are assembled. The board used in the 1200D is a single sided pcb and is no doubt much cheaper than the 1500D and is not secured into the heatsink as well either. The quality of the solder joints is superior on the 1500D. I know that the SAE-1200D I have here has mismatched date code parts in the output section which I doubt you would see in the 1500D. The part may be technically the same but different batches have slightly different characteristics and although they may work just fine together they are not as reliable as an output section full of matching date coded parts. The 1200D also doesn't like to see too much more than 15 volts power input. This isn't a knock on the 1200D by any means. It is an awesome "budget" amp . The 1500D is a great high end amp and well worth the extra coin if you plan on wiring below 1 ohm . If you can live at 1 ohm nominal or higher than the 1200D should last you a long time as well.
