Why IB like IB
Upgrayedd
Double dose of the pimpin
For years I have wanted to try an IB setup. Well. I finally Decided to give it ago. While waiting for the rack to free up to put my engine In I decided to start the project. With only a jigsaw, square, and chalk I got started.
After Inspecting the deck, I decided that it was just too uneven to slap some mdf on it and sprayfoam it. I wanted to make use of anything on it. If it went there it was rigid. So...
After measuring and marking this happened.
I then measured and cut the blockoff for the seat
There is a 2nd layer now glued to the board that fits the shock mount better
I also made the deck cover that will be more cosmetic than structural. Seen here with seat cover
You might ask WTF is going in that gaping hole? This
1" L channel 1/8" thick 1/8x1" mounts for the baffle. I still need to cut radii out of the ones on the side and finish a parameter. to mount the baffle
After some massaging of the hole I stuck it in.
I then cut the baffle.
As with the seat block it is 1" 2 layers of glued 1/2"mdf.
I still have a long way to go and updates will be slow coming. After the baffle basket gets welded in, there will be misc bracing for it above and below. I am also welding in bracing behind the seat and plating in larger gaps. I will be using spray foam along with your abcs of dampening, just sparingly. You don't build an enclosure to flex and I feel IB is the same way. I will be running 3 10s in this byotch. The above was a span of 2 nights and about 10 hours
Peas.
More will be a long wait. I work at 3 shops (none audio related), along with being Mr. Mom during the day. This vehicle needs an engine before audio. And I want my sprite on the road before the end of this coming summer, so I am occupied to say the least. On top of that I need family time which is more important than any of this. There may be 2 updates a month or so.
Nothing too exciting but I got some time.
I scraped off the factory sound deadening, Luckily this wasn't as stuck as usual. Took less than an hour
I then sanded the deck and the frame.
Dropped the frame in and tacked it in. Started stiching it. Against my better judgment I didnt seam weld 1st. This bit me in the *** when the seams that are 1/2" from the frame started distorting. before I went further I spot welded them best I could.
This was one of the most awkward things I have had to weld. I wish I had the motivation to pull the back glass but I don't. Luckily outside of the pics, the birdshit welds won't be seen. All in all I'm happy with how rigid things are getting. I think once I get bracing and gussets in, the deck will be rigid enough to pass for a real baffle.
peas.
Thanks for the compliments. I'll reveal equipment once It goes in and is measured. All I will say is it is an inexpensive sub that is not suggested for IB. Lucily I had transfer function data for my vehicle, when modeled it was pretty flat and should have more than sufficient output before hitting x-max.
Good stuff.
Which subs are you going with?
... I really need to learn to weld.
Its not as hard as it looks. I couldnt do it at all. Started playing with a welder and I have grown alot. Just play around.
The pics of the radiator in the truck screwed me up lol.
Yup. I learned about 5 years ago, I got tired of waiting for people to weld stff for me so I sat at the tig and went to work. It was funny. Most people learn to mig first. I could tig sufficiently for almost a year before I could mig.
Rad is in the trunk because engine is out. When I go in to work on the car if the rack is tied up, I'm going to hang out anyway, so I just work on the audio.
Thanks man. I'm not an installer by trade, haven't been for ~5 years but I have never been on the level of some of these guys. However I try to approach everything in life in the same manor; do what is necessary with as little as possible. IMO it would have been just as difficult do use 2-4 pieces of mdf, foam and deadener.
Upgrayedd
Upgrayedd
Ohio
RMF419
BP1Fanatic
BP1Fanatic
