why dont this setup sound good???
jr_casteel1999
ok have had this setup in my truck and this is how i would like to place everything but the subs sound best when they are facing the rear but the 2 separate boxes are to big to set side by side. does anybody know how i could keep this setup but make it sound better without building another box? if you had this setup how would you do it? there are 2 jl 13w7s and 2 jl 1000/1 amps. there are 2 kinetik batts setting behind the boxes.
have the subs fired up?
---------- Post added at 03:55 PM ---------- Previous post was at 03:54 PM ----------
the way you have it set up you are most likely cancelling out the sounds thus reducing output, theoretically
building a different box is what i dont want to do at the moment. cheapest i can get a box built around here is 300 and with xmas times are tough right now to be spending on the system
i did have them standing up facing the rear but the problem with that is they stick way up and look like crap and if i turn hard the fall over
strap those mofos down
hit up one of the builder here, see if they can help you out. I swear there are those on here in Ohio that can probably hook you up
Hit me up after the holidays...I will have another great promotion coming in January.....Your looking at a 4.5 to 5 cube net enclosure for the pair......An enclosure that size from me is $170 plus whatever your actual shipping rate is.........I bet we could get it to ya for a total of $250 shipped and I have been building SOLID enclosures for over 23 years.....
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
575
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
978
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
898
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
jr_casteel1999
jr_casteel1999
columbus ohio
bgowdy
    May 16, 2024
    May 16, 2024
