This is about the only intelligent response I've seen in this thread about why a cap is even used. It's there to help out the SLOWER response of the alternator and battery. A cap can respond to transients faster than the biggerst alternator or battery can. It's that simple. Now, long bass notes will drain a cap and then it will be come useless until it can recharge, so for people who listen to music with lots of sustained bass notes it won't help much. But for drum beats and what not, it can and does help. I've used them for 10 years and I like them. But, they are expensive for sure so I would say either pick up a used one or upgrade your alternator for the price of a new one. A cap won't really help a weak alternator, but it can complement a strong charging system. My .02.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifOriginally posted by Grand AMature heres what a farad does. it stiffens the amount of fluxuation in your positive polarity. meaning when the amp takes large amounts of current, the cap will help stabalize the current faster back to 14.4 volts. and it will help so the when the amp takes power it doesnt go as far lower then 14.4 volts. it wont stop your headlights from dimming, it just makes it so they dont stay dim as long. but 1 farad wont do much at all. neither will 4 1 farads. to really make a difference you need a good 15+ farad cap. they are very expensive though. this is why the best way to go is to respool the alternator or get an upgraded one. of course if you upgrade the alt, make sure you upgrade the battery so it can hold all the extra ampheres.
There is only one problem here: An alternator is faster source of electricity than a cap.Originally posted by SUX 2BU This is about the only intelligent response I've seen in this thread about why a cap is even used. It's there to help out the SLOWER response of the alternator and battery. A cap can respond to transients faster than the biggerst alternator or battery can. It's that simple. Now, long bass notes will drain a cap and then it will be come useless until it can recharge, so for people who listen to music with lots of sustained bass notes it won't help much. But for drum beats and what not, it can and does help. I've used them for 10 years and I like them. But, they are expensive for sure so I would say either pick up a used one or upgrade your alternator for the price of a new one. A cap won't really help a weak alternator, but it can complement a strong charging system. My .02.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
?? Metals have delocalized valence electrons. The flow of electrons from one end of the wire to another isn't like a spitball going through a straw, it's like a straw filled with spitballs where you add one more to one end and one of the ones already in there falls out.Originally posted by SUX 2BU Okay, BUT those 90 amps are not always sitting there in the power cable ready to be taken by the amp. It's the length that the alternator is from the amp that also is a contributing factor. So, taking wire length into account what current is going to be there first? The cap, which is say 18" wire length from the amp or the alternator which is over 15+ feet? While electricity does travel extemely fast, in terms of nanoseconds, the wire length difference can be the determining factor.
There is reserve capacitance inside your amplifier power supply for a good reason... Why waste space pretending you can augment it?Originally posted by SUX 2BU This is about the only intelligent response I've seen in this thread about why a cap is even used. It's there to help out the SLOWER response of the alternator and battery. A cap can respond to transients faster than the biggerst alternator or battery can. It's that simple. Now, long bass notes will drain a cap and then it will be come useless until it can recharge, so for people who listen to music with lots of sustained bass notes it won't help much. But for drum beats and what not, it can and does help. I've used them for 10 years and I like them. But, they are expensive for sure so I would say either pick up a used one or upgrade your alternator for the price of a new one. A cap won't really help a weak alternator, but it can complement a strong charging system. My .02.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I've tested my system both with, and without. Both audible, and voltage, and visual.Originally posted by SUX 2BU But how much reserve? An outboard cap is insurance so to speak. Everybody has their own opinion on caps. Mine is that I feel it does it's job and therefore I use one.
