why do my FUSE keep getting blown????
jamezruiz
okay so i got a KENWOOD KAC-9104D 1800watt max 900rms. 500RMS at 4ohm, 900rms at 2ohm and 900rms regulated at 1ohm.
i hooked it up and it blows fusses like crazy, and it cuts off sometimes.
i have 2 Pioneer Premier TS-W1207D
12" 1200W Dual 4-Ohm Subwoofer wired down to 2-ohm.
whats wrong? how do i fix this??
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
2 dual 4 ohm subs dont wire to 2 ohm. only 1 or 4
each of my subs are down to 2ohm, i think, but i dont know crap about wiring, any enlightenment?
and what do you guys mean with the power and ground being crossed?? whats the fix?//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
What size power wire and fuse you using Broseph?
i have a kac8452 4 channel amp that did the same exact thing. Its either a loose ground, or the power is touching the ground. hook it up to another vehicle and see if it does the same thing. isolate the problem.
ok completely disconnect the amp have no wires hooked up at all. make sure the fuse at the batt is out. now go back and hook up one wire at a time make sure nothing is where it's not suppose to be, no loose stands etc. make sure your gound is a good solid ground. do not hook up rca's or subs yet. now after everyting is done put the fuse in and tell us wat happens
WELL I DID WHAT U SAID AND THE AMP POWERS UP, BUT SINCE THE RCA AND SUBS WERE NOT HOOKED UP , NO SOUND CAME OUT FROM IT , BUT THEN I WENT AND HOOKED EVERYTHING UP AND IT BLEW 3 FUSES TOO, when i put in the fuse it made a spark sound //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
NOT SURE WHAT I DID WRONG
i ran that same amp but the older model for a month with 8 guage wiring and all was good but for 900 RMS i probably would run at least 4 guage. . so you may have a different problem. are you replacing with the same size fuses? how did you set the gain? mabye you have a short in your wire some where?
jamezruiz
jamezruiz
Russellville, AR
jamezruiz
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
