why am i clipping
tyronekndrck
I think my subwoofer is clipping. was playing fine until I upgraded to 0 awg from 4 awg and wired my aux battery parallel and grounded my amp to the aux battery. I went back over my wires and couldn't find an issue. its wired correctly as I see. do I maybe have to reset the gain knob after upgrading power wire due to more current? and also it clips full throttle even when I mute the music, goes away only if I turn the car off or pull the rcas from the amp. my grounds and power terminals are also tight as possible. help me out
How can you be clipping while on mute with no music?
kinda sounds like wiring your amp directly to your aux battery was a bad idea. did you add a ground from your aux battery to front battery and the car body near the aux battery?
---------- Post added at 11:40 AM ---------- Previous post was at 11:39 AM ----------
this makes me think OPs signal into the amp is all screwed up due to a ground loop or something
Ground the amp to the chassis. Ground the aux battery to chassis too. And what are you calling clipping? What does it sound like?
Well it's not clipping. When I turn the key before my cd player even load up there's a loud heartbeat rythem even if I turn the cd player off
tyronekndrck
tyronekndrck
cincinnati oh
gckless
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
