I have a whole system for sale and will sell as a whole or parted out but hopefully all together. Like new Kicker CVX 15's I still have the box they were delivered in as well as some of the inserts that were included. They are 2000 watts apiece, 1000 watts rms. The box is built for a Chevy Tahoe, its custom of course with an amp rack . Amprack currently holds 2 amps, a power cap and optima battery.
Subs are $150+shipping each and box is $200 local
I have two amps from my system that are for sale. The one on the back of the rack is a Kole QX21920 1920 watt amp.
# Kole Audio QX21920 1920 Watt 2 Channel Amplifier
# 4 ohm RMS Power: 370 x 2 Watts
# 2 ohm RMS Power: 440 x 2 Watts
# Mono RMS Power: 880 Watts
# Bridged Max Power: 1920 Watts
# Dimensions: 20.7 x 2.3 x 11
# Full Mosfet Power Supply
# PWM Circuitry
# Full Selectable Crossover Hi/Full/Low
# Three Way Protection Circuit
# 2 Ohm Stable Stereo
# Tri-Mode Capable
# Variable Low Pass 40Hz-250Hz
# Variable Hi Pass 40Hz-250Hz
# Variable 18 dB Bass Boost
# Frequency Response: 10Hz to 30KHz
# S/N Ratio: 98 dB
# THD: 0.02%
# System Distress Indicator
# 4 Gauge Power/Ground Connection
# Platinum Plated RCA Connectors
# Line Output
# High/Low Level Inputs w/ Floating Ground
$90+shipping
Flip out in-dash Panasonic CQ-VD7700U
Features:
# 4 x 70 watts power
# 7 inch, 16:9 Screen, 336,960 Pixels
# Touch Panel Operation, TFT Active Matrix LCD
# Internal Light Source L-shaped CFL
# Motorized Operation with One-Touch Tilt
# Auto/Manual Dimmer
# DVD Audio, DVD Video, Video CD, MP3, CD-R/RW playback
# Anti-Shock Memory
# 35W x 1 Center Channel Amp
# Parametric Equalizer
# CD Changer Control
# Dolby Digital/DTS Decoder
# Dolby Pro Logic/Pro Logic II Decoder
# Built-In DSP
# TV Tuner with Diversity Antenna
# Still Picture (JPEG) Playback
# MPEG4 Movie Playback
# Subwoofer Output
# Camera Input
# Video Capture
# Multi-Function Joystick
# Wireless Remote Control
brain
$715+shipping
kicker kq9
# 1/2 DIN size — installs in or under your dash (underdash brackets included)
# 8 bands of equalization (12 dB cut/boost at 125, 250, 500, 1,000, 2,000, 4,000, 8,000, and 16,000 Hz)
# variable subwoofer EQ (variable from 40-60 Hz, 12 dB cut/boost)
# subwoofer level control (0 to +6 dB)
# high-pass crossover (100 Hz at 18 dB per octave)
# low-pass crossover (variable 60-120 Hz, at 18 dB per octave)
# preamp- and speaker-level inputs
# three sets of RCA outputs (this unit has no built-in amplification — amplifiers are required)
# switchable green/amber illumination
# EQ defeat switch
# input sensitivity: 150 mV to 10 volts
# 7-1/8"W x 1"H x 5-1/16"D
http://www.crutchfield.com/p_20603KQ9/Kicker-KQ9-Signal-Processor.html?tp=116
$65+shipping
# PWM Circuitry
# Tri-Mode Capable
# S/N Ratio: 98 dB
# THD: 0.02%
# Line Output
$90+shipping
Features:
# Anti-Shock Memory
# Built-In DSP
# Subwoofer Output
# Camera Input
# Video Capture
brain
$715+shipping
kicker kq9
# EQ defeat switch
$65+shipping
