who wants to hook me up with a cut sheet?
SAG3
________
for this box
its 2.5 @ 32 from moe lesters box plan thread.
free would be great.
Pulling up an old thread but, what did you use to get that cut sheet? I have been looking for the web based program that gives you a cut list (not as nice as that one ^) I thought I had it saved but for the love of god I cant find it. Anyone help me out?
Cutlist plus. You can use the eval version forever. Only thing is, it only lets you add up to 5 different sized pieces, but that's not a problem when building boxes since top and bottom and side pieces are usually the same size.
For the record , I was doing them before Dante ever even thought of it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Just not as colorful.
I personally use sheet cutting suite.
was never registered on the road so no, here in maine for a vehicle of that age all you need is a bill of sale. i still have original dealer...
666
152
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
SAG3
________
SAG3
Kauai, Hawaii
Pyro_By_Nature
maylar
    Jun 2, 2024
    Jun 1, 2024
