Who offers Good oversized 1/0 wire
Looking for some good true 1/0 or actually oversized powerwire .Need for the majority 95% of my power wire run , probably reduce to standard"0 gauge " at my amp Best bang for the $?
But still have the ability to fit into typical "0" input distribution block. Does anyone make the adapters for true over sized 0 gauge anyone ever run into issues fitting into amp terminals?
Looking for some good true 1/0 or actually oversized powerwire .Need for the majority 95% of my power wire run , probably reduce to standard"0 gauge " at my amp Best bang for the $?But still have the ability to fit into typical "0" input distribution block. Does anyone make the adapters for true over sized 0 gauge anyone ever run into issues fitting into amp terminals?
Go to amazon and put in welding wire, you will find a veritable plethora of ofc true spec wire, I got mine there for about 1.20 per foot.
Pointless
Why? cause there's no pictures? Its ok, just read it.
I wasn't being a di**, I was making sure OP saw the sticky. Glad you made an effort to help, I must have missed that in this thread. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
I probably went over this s*** a thousand times
royal excellene 1/0 vs eb flex 1/0 EB is waaay better.
Wish I would have known about the EB Flex before I dropped 250 on a 50 foot roll of stinger power wire the Stinger is tinned but I have no idea if that actually helps anything except corrosion
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
81
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
555
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
901
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
872
Androidaaron36
Belleville mi
Boomin_tahoe
    May 16, 2024
    May 16, 2024
