Who has owned an IDmax?
Trey803
GAMECOCKS
plannin on getting one. The specs say .9cf sealed but seems kinda small for such a beefy sub. n e ways .9 is the MOST space I have for a box so Im just wondering if it will perform well in that enclosure. Also I saw somone mention that they like around 700 watts but they are rated at 1000. My amps is 1200 will that be too much...should i get the d4 run it at 2 ohms and send it 800 watts?
i had mine in a 1.2ish sealed and was not very impressed by it. then i but it in a 2.5 ported to 32hz and now i love it. still would like to get a second one, but the jump from sealed to ported is incredible.
the ported enclosure seems to have a peak at 40hz....maybe you guys like a little extra low end but I'm going for a flat curve
I loved my 12 in 1.25 off ~750w. For the 10, I think your box will be fine if you stuff it full of polyfill. For the 1200 watts, just be gentle with the gains. Nothing wrong with having a little overhead.
http://www.imagedynamicsusa.com/pdf/IDMAX10%20V3%20D2%20spec.pdfI'm just having a hard time believing that it wont sound good in a .9 from the frequency response graph, but from what all you guys say it wont? How much power were all of you sending it?
I dont see what the problem is. They recommend .9 and the max you can build is .9 so why dont you try it out? What does it matter if people recommend something else if the MAX you can build is .9 anyway?
The enclosure sizes I recommended was for a 12".
Get the D4 and run at two ohms.
Trey803
GAMECOCKS
Trey803
SC
johnson
