Who all has ran power wire under the car?
In my silverado I had 8 runs of 0 gauge under it, didn't use any fuses or conduit either lol.
The frame has the angles on it and I ziptied it up inside the frame rail
Never had a single problem
I've done it with zero issues...just use common sense and make sure you're not rubbing the wire anywhere, or just use split loom over the whole thing.
Running it is not the issue. Ive ran wire many times, just not under the car.. This thread was just to see how many were doing it..
the pvc pipe thing should work
i thought about running just the wire once....got to thinkin about it and decided against it but never tried the pipe
but running just wire = dumb
especially if u drive over rocks or go mudding alot?
I did it once on my 1981 chevy malibu that I had throughout high school and college in the late 80s early 90s. I ran the wire in a flex steel conduit and used some heavy duty zip ties to channel it in the frame of the car. You just want to make sure there is no way the wire can get pinched by anything or come loose because I wouldn't want to see the aftermath of it snagging on something while I am driving on the interstate....
i've done it in a 96 lumina before, but since i did it i guess i is dumb. LOL
Seems like common sense here. If you drive a rock crawler, or can lay frame, dont have the wire exposed below the frame. And always run it in conduit or heavy-duty water proof wire loom. Full framed vehicles practically beg for you to do this, just run it inside the frame rail and pop a hole in the floor where you need it to come through. You can get bulkhead fittings at your local hardware store that attach to most common flexible conduits.
171
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Towncar
Towncar
who knows
quins90lac
