Hi guys its a toss up and I ordered the polk mm 10" dvc's (2) today but need verification - tomorrow before shipped to me. I am wondering if I should switch to the jl 13TW5 which was my original choice. I'm a family man so no need for a massive setup, just some thump that will blend well with the front stage.
It will be run off of a PG ti 600.2 so should push the same power 650ish to each setup.
Polk Pro's over JL - saves me about 150. If 1 goes I will still have the other until replacement comes, more versatile load than JL
Con's - mounting under rearseat of the tundra 6" depth and I may have to add spacers to the seat/work a bit more to fit them in (1.3 cu ft after sub displacement)
JL Pro's over Polk- 1 sub, will fit without any modifications, just a simple underseat box.
Con's If it breaks, no sound until replaced. More expensive. 3 ohm load ***** if anything happens to the PG amp.
If you had to choose this for yourself, which route do you go? Thanks guys.
