Which will give me more power?
Personally, I think the Diamond amp is one of the best built 1200 watt amps money can buy. That being said the Hifonics amp may put out similar power, but at higher distortion numbers.
If you already one the Diamond, you should keep it and forget about the Hifonics amp.
Before clipping the THD comparisons would be indistinguishable - both a fraction of a percent. Any power beyond 1% would be considered unusable (although a LOT of listeners use it).
Power-wise, these two amps are probably close enough to call the same.
tooshort_128
tooshort_128
Sterling, VA
n2audio
