amp rms vs peak
peak power is the absolute maximum that an amp can produce for a VERY short time and more than likely the sine wave is severely clipped and can damage speakers. it's a very pointless figure when looking at an amplifiers specs...
they use peak for sale gimics //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif ie sony xplod, they say 1300watts on the subs and amps but can only take/produce so little
Yep peak power is advertisement. On ebay you can buy a 2000 watt MAX amp for $99 bucks. In reality it might put out 400-500 rms on a good day. Never go by max wattage rating, only use the actual rms rating.
Multiply RMS by sqrt(2).
Yup, or divide by .707 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Sure, if you're in a lab looking at sine waves.
Peak numbers are manufactured to boost sales.
bingo
which is why...
peak means nothing...
Wiki has a pretty good summary of "Peak" power, or PMPO
Peak Music Power Output (PMPO) (sometimes misused in advertising as Peak momentary performance output) is a much more dubious measure, of interest more to advertising copy-writers than to consumers. The term PMPO has never been defined in any standard but it is often taken to be the sum of some sort of peak power for each amplifier in a system. Different manufacturers use different definitions, so that the ratio of PMPO to continuous power output varies widely; it is not possible to convert from one to the other. The term PMPO is considered misleading and meaningless by audio professionals. Most amplifiers can sustain their PMPO for only a very short time; loudspeakers are not designed to withstand their stated PMPO for anything but a momentary peak without serious damage. Sometimes the PMPO which can be delivered into an unrealistic resistive load, rather than a real loudspeaker, is quoted. There have been genuine attempts to measure 'peak music power' as described below, but in general the term is not at all useful.
stump
stump
bangor maine
blazinb2000
Mike Mccabe
