Which subwoofer do I need?
So I currently have in my possesion a Kicker zx750.1 and was wondering which of the Alpine Type R 15" I needed.
Alpine SWR 1542D or the Alpine SWR 1522D?
I'm pretty sure its the 1542D I want but I really would like confirmation before I go out and spend $200 on a sub that wont be able to reach it's full potential.
Also are Kicker amps any good because I'm also planning on swapping out all my component speakers for new ones and would like to power them with a 4 channel amp.
I'm looking at the Kicker zx350.4 which is rated at 90wx4 so would I be looking at getting speakers rated at 90rms?
Sorry I was going to post links to all the specs for easy reference but it wouldnt let me due to being a new member;)
your amp is 2 ohm so which ever subs you get you need to be able to wire it down to 2 ohms
pair dvc 4 will wire to 1 ohm
pair dvc 2 will wire to 2 ohm
single dvc 4 will wire to 2 ohm
you can probably get better sub than that Alpine for the money
in my opinion Kickers are too pricey and depending on what 4 channel you want you can probably get a less expensive amp that will do the same wattage.
a lot of people did not respond probably because this was asked a lot and if you search you will find the answer but good luck with your build
Seriously 45 views in the last hour and not one of you can answer a simple question? Oh wait, it's because I've looked at other threads and the pattern seems to be a bunch of morons who can barely spell trying to sell people ****.... ****** community here and hands down one of the worst forums I've ever seen.
calm down...
the older zx amps are good amps, im not too sure of the newer ones but if its new kicker i wouldn't pay retail for it, same power can be had for less, or ALOT MORE for what you want to pay for a new kicker amp, now as far as the sub goes theres alot more options out there to look at man
instead of getting that alpine for $200 you can get one of these c2 audio presale for $99
this comes in dual 2 or dual 4, if you want just one sub you can do a dual 4 for your 2 ohm sub amp, or if you ant to run 2 of these you can get the dual 2 for fianl impedance of 2 ohm.
if you ask me I will get dual 4 ohm for 1 sub and later on get another dual 4 ohm to wire down to 1 ohm and get a more powerful amp.
If you want 15's they are almost ready to get the 15's to go on presale, only if you can wait
presale on Sub 12" 600watt $99
C2 Audio Threatcon-2
Specifications:
12" Threatcon-2 Subwoofer
600 Watts RMS
Available in Dual 4 Ohm and Dual 2 Ohm
Dual 2 Ohm: Threatcon-2 12d2
Dual 4 Ohm: Threatcon-2 12d4
3" Copper 4 Layer Voice Coil
Double Stacked 160 oz Magnet
High Current Flat Woven Tinsel Leads
Dual Spider Pack
Dual Stitched Non Pressed Paper Cone-
with Mid Excursion Foam Surround
Enclosure Recommendations:
Sealed: 1.0 - 1.25 ft^3
Ported: 1.5 - 2.0 ft^3 @ 35hzSealed: 2.0 - 2.50 ft^3
Ported: 3.0 - 4.0 ft^3 @ 35hz
T/S Parameters:
FS: 36.7HZ
VAS: 40.9 DM3
QES: .44
QTS: .40
BL: 16.8
MMS: 167.7G
SENS: 91.5 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
Jordan515
Jordan515
Des Moines, IA
naughtyca
