Which Subs?
I don't have a budget ,was thiking of getting memphis shallow mounts and getting a new amp also and the subs are going under the back seat
again how much space do you have to work with, we need measurements so we can know what subs to suggest.
you might have a little difficulty fitting 2 12s under the back seat though, unless your raise it to give your self the airspace you need.
measurements are 19ft 1/2 x 8ft 1/2
Try it like this, assuming inches.
19.5" width x 8.5" height x ??.?" depth.
He also needs the measurement from the front of the seat to the rear wall of the cab.
The depth will tell him how tall of a sub you can use. The height will tell him the volume of the enclosure, so he can match the proper sub to it.
It would also help a bit to tell what kind of music you listen to. As well as what kind of sound you want. Nice clear punch or pounding loudness? In a lot of cases there are a whole lot better performing and sounding subs than are popular in your area. Since you said memphis most likely you are more interested in loudness than clarity.
Try it like this, assuming inches.19.5" width x 8.5" height x ??.?" depth.
http://www.foxacoustics.com/ProductDetails.asp?ProductCode=GM%2DXC%2D212%2D99
only boxes i would buy for a truck unless im making a custom one myself. and with those measurements id go with
nany
nany
phoenix
slim2fattycake
vegang
vegang
