which subs to use with mrd 605
liquidrider_321
hello which subs would be best to run from an alpine mrd 605 in sealed box 1.92 cu ft a piece, the amp pushes 600 watt rms at 2 ohms and 400 at 4 ohms so if i did go with a dual voice coil setup how could i wire two of them to two ohms? i was thinking of either alpine type s or type e or something else not much more then 100 a piece for 2 12's. any help much appreciated thank you ohh ya i would like a mix of sq and sp(forget what thats called)
forget about alpines with that big of a box. under wiring there is a thread that shows all types of coils,ohms,and wiring options. your phone book idea is not good, don't do it. you'll have to search around for the subs online. you can usually find recommended box sizes in the specs. the alpine type r's for instance i think are .85 sealed.
liquidrider_321
liquidrider_321
griswold ct
azimuth
