which sub for the best bass
here the spec is it helps i don't know much about subs
Pioneer Premier TS-W3001D2
New 12" HIGH SPL DESIGN
Long Throw High excursion design for maximum bass
Power handling: 3000 watts each max
RMS power handling: 1000 watts each
Double Stacked 110 oz. magnet structure for superior power handling
High Strength Cast Aluminum Basket
Heavy Duty- 12 ga Spring Loaded Platinum Plated speaker terminals
High-Temp voice coils with spun-laced Nomex re-inforcement collar
Dual Voice Coil (DVC) Design-
Dual 2 Ohm voice coils
frequency range:18-700hz
IMPP Cone with Carbon/Glass Fiber Reinforcement
Long throw Half-roll High Density Compressed Poly-Foam surround
extended pole piece
vented spider cavity
bumped back plate for increased excursion and performance
long stroke design
Sensitivity:92 db @ 1w/1m
Mounting depth: 7.5"
Mounting diameter: 11.1"
works great in sealed or ported enclosures!
sealed box recommended volume:.5-1.0 cubic feet
ported box recommended volume:1.4-2.25 cubic feet
ALPINE SWX-1243D
12" Subwoofer With Dual 4-ohm Voice Coils
Pulp/Fiber Cone Reinforced with Kevlar and a Layer of Rohacell Plastic Film
Santoprene Rubber Surround
Cast Aluminum Frame
Power Range: 500-1,000 watts RMS (500 watts per coil)
Peak Power Handling: 3,000 watts
Frequency Response: 24-200 Hz
Sensitivity: 84 dB
Top-Mount Depth: 8-11/16"
Sealed Box Volume: 0.65-1.25 cubic feet
Ported Box Volume: 1.0-2.0 cubic feet
One 12" Dual-voice-coil subwoofer
1 Rubber Mounting Ring (installed)
1 Top-Mount Rubber Concealing Ring
1 Bottom-Mount Rubber Mounting Ring
2 Voice Coil Configuration Jumpers
2.5mm Hex wrench
the Xtype seems better but i don't know?
i hade both ALPINE SWX-1243D 12" TYPE X 3000W and the Pioneer Premier ts5000spl i never tried the Pioneer Premier ts 3000 but i liked the Pioneer Premier way better it was built better and louder ..
You're comparing the 5000SPL to a Type-x? //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
no i hade both and i was giving my op.
"Built better and louder" is a comparison. The type-x was designed with SQ in mind, the 5000SPL (and 3000SPL as well) were built to get very loud. Two totally different directions.
OP needs to tell us if he wants sound quality, or SPL... Then a recommendation can be made.
Subsocket
Subsocket
Perth
Subsocket
