which sub--final decision
hunter121
Dude...I'm searching!
Hi all Ive been searching these forums like a mad man and finally decided on 3 diff 12'' DVC 4ohm subs....I just need your expertise to figure out which would be best for me.... They are alpine type S
http://www.sonicelectronix.com/item_2175.html
Diamond D3
http://www.sonicelectronix.com/item_5527.html
Soundstream XS
http://www.sonicelectronix.com/item_5468.html
The subs will be put into a 1.0 sealed box that will be firing down under the back seat of my 2500hd chev ext cab. I mainly listen to country and rap (what'a combo)
im interested in 60/40 split on SQ/SPL ....the subs will be wired down to 1OHM to match the sub output of this amp Directed d2205
http://www.sonicelectronix.com/item_4335.html
Well thank you for your help in advance.....I appreciate it ...I think I gave all the info needed with the links and my application...if not just ask away with whatever info you need.
By the way if you can think of another 12 sub that is 4ohm dvc in the sub $100 range a piece Im all ears thanx again Hunter121
Sorry I shoulda posted mounting depth:crazy: ...It is 7.25 so I have room //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif Thanx for the very quick replys by the way Hunter121
if you wanted used in almost new condition my brother has some subs for sale that look and play like new and sound good I believe they will work well for you as well there ma's I have them posted in the classifieds and he has 3 for sale but if you wanted 2 or 1 i am sure he would sell seperate like that. and save you some cash there pretty much the same specs as those but not 100% sure on mounting depth but can find info.
Good looking out Voa I will cheak out the classifieds and keep those in mind...no worries on the mount depth im sure they would fit but ill dbl cheak also..anyone else have any thoughts on the subs I have posted or any other options to consider?? Thanx hunter121
hunter121
hunter121
washington
VOA_NIGHTMARE
