which set of subs?
  • 4
Yitzy
ph3@r
113
MA
I need all opinions. I am planning on getting a nice system but keeping money in mind. So for subs should I get:
3 JL W0 10 inch
2 or 3 JL W0 12 inch
1 or 2 JL W3 10 or 12 inch
(how much better is a 12 inch W0 to a 12 inch W3?)
I would be putting them in a sealed box and only really want to thump without spending over a grand for the HU, Amp, and subs combined.
i would suggest 2 12w3's not that the wo's are bad ...and a memphis 500d with a pioneer 6400 (lots to choose from but it has sub out i do believe)
If you are definately stuck on JL I would go with 2 12" W3's if you consider other brands we can talk. HU panasonic sony pioneer you cant go wrong really with any of those oh and ALPINE. Amp I would have to say depends on budget but a JL 500.1 could do the 2 W3's in my opinion. But i would go with maybe planet audio I love thier amps!
jrmax I am not stuck on JL its really just one of the only great brands I have heard. I just have looked at other brands and the subs need a lot more power so that entails a more expensive amp. If u have other suggestion please pass them on! Thx a bunch guys!
I was just looking around at the amps and the JL 500.1 is 400 DOLLARS! I know it is a great amp for the 2 W3's but if there's a cheaper good one I would go with it. If there is not then I may have to go with the W0's because they dont need as much power. How much less bass do they produce (a lot less excursion?)? Thx a lot for ur responses!
i'd suggest ALPINE MRV-T757(4ohm stable), they cost $299 at http://www.onlinecarstereo.com ....... i think it can drive your JLw3 just fine..(i think, consult others too, if u plan to get this one)
check it out...//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
ALPINE MRV-T757
2 channel
* 225W x 2 (4 Ohm Stereo)
* 750 x 1 (Bridged 4 Ohm)
FEATURES
* RMS Continuous Power (Watt) (at 12.0V 20-20kHz): 4 Ohm Stereo (0.08% THD) 75W x 2; 2 Ohm Stereo (0.3% THD) 150W x 2; Bridged 4 Ohm (0.3% THD) 300W x 1
* RMS Continuous Power (Watt) (at 14.4V 20-20kHz): 4 Ohm Stereo (0.08% THD) 100W x 2; 2 Ohm Stereo (0.3% THD) 200W x 2; Bridged 4 Ohm (0.3% THD) 400W x 1
* S/N Ratio 105dBA
* Frequency Response (+0, -1dB) 10-50kHz
* 24dB HP/LP Crossover (30-200Hz)
* 1-Band Parametric EQ (30-200Hz)
* Subsonic Filter
I have been debating on it and am either going with 2 12 inch W0's or a 12 inch W6 prob gonna go with the W6 and any amp suggestions for (what is rated as a 300 watt constant) W6.
110
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
591
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
711
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Send me all the items. Once I receive them, I will verify everything in your classifieds. If someone buys them, I will ship out. You would just...
970
Yitzy
ph3@r
Yitzy
MA
Yitzy
    May 16, 2024
    May 16, 2024
