which set of subs?
Yitzy
ph3@r
113
MA
I need all opinions. I am planning on getting a nice system but keeping money in mind. So for subs should I get:
3 JL W0 10 inch
2 or 3 JL W0 12 inch
1 or 2 JL W3 10 or 12 inch
(how much better is a 12 inch W0 to a 12 inch W3?)
I would be putting them in a sealed box and only really want to thump without spending over a grand for the HU, Amp, and subs combined.
If you are definately stuck on JL I would go with 2 12" W3's if you consider other brands we can talk. HU panasonic sony pioneer you cant go wrong really with any of those oh and ALPINE. Amp I would have to say depends on budget but a JL 500.1 could do the 2 W3's in my opinion. But i would go with maybe planet audio I love thier amps!
jrmax I am not stuck on JL its really just one of the only great brands I have heard. I just have looked at other brands and the subs need a lot more power so that entails a more expensive amp. If u have other suggestion please pass them on! Thx a bunch guys!
I was just looking around at the amps and the JL 500.1 is 400 DOLLARS! I know it is a great amp for the 2 W3's but if there's a cheaper good one I would go with it. If there is not then I may have to go with the W0's because they dont need as much power. How much less bass do they produce (a lot less excursion?)? Thx a lot for ur responses!
i'd suggest ALPINE MRV-T757(4ohm stable), they cost $299 at http://www.onlinecarstereo.com ....... i think it can drive your JLw3 just fine..(i think, consult others too, if u plan to get this one)
check it out...//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
ALPINE MRV-T757
2 channel
* 225W x 2 (4 Ohm Stereo)
* 750 x 1 (Bridged 4 Ohm)
FEATURES
* RMS Continuous Power (Watt) (at 12.0V 20-20kHz): 4 Ohm Stereo (0.08% THD) 75W x 2; 2 Ohm Stereo (0.3% THD) 150W x 2; Bridged 4 Ohm (0.3% THD) 300W x 1
* RMS Continuous Power (Watt) (at 14.4V 20-20kHz): 4 Ohm Stereo (0.08% THD) 100W x 2; 2 Ohm Stereo (0.3% THD) 200W x 2; Bridged 4 Ohm (0.3% THD) 400W x 1
* S/N Ratio 105dBA
* Frequency Response (+0, -1dB) 10-50kHz
* 24dB HP/LP Crossover (30-200Hz)
* 1-Band Parametric EQ (30-200Hz)
* Subsonic Filter
I have been debating on it and am either going with 2 12 inch W0's or a 12 inch W6 prob gonna go with the W6 and any amp suggestions for (what is rated as a 300 watt constant) W6.
Yitzy
ph3@r
Yitzy
MA
Yitzy
Doxquzme
    Aug 1, 2026
