Which one is the better deal?
i have no idea about the new re stuff.... but the specs look good, the brutus i'm familiar with and it does about 80% rated... try searching more info on that re... bench tests...
RE Audio CTX-4200.1Hifonics BRX1100.1D
I found both of these online for around 200 dollars. Which one would be better?
Plan on using it a 1 ohm for the brutus but 2 ohms for the re
between the 2, the RE "claims" be stronger via the specs. but honestly i would go with the hifonics. i would probly look into some other options, you can probly get a better amp for the same money.... but whats your budget i may be able to asisst on finding a better amp.
If your budget is really 200 bucks you can get a wayyyyy better amp on here for that!!!!
---------- Post added at 10:47 PM ---------- Previous post was at 10:46 PM ----------
... AND i AGREE WITH THIS.....
---------- Post added at 10:48 PM ---------- Previous post was at 10:47 PM ----------
If your budget is 200 you can get a wayyyyy better amp off here for that!!!
Here you go, this is a MUCH better amp, also a smexy amp as well //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif :
Precision Power BK1800.1D Class D Amplifiers at Onlinecarstereo.com
the amp is $209, but use the code "fall13" at checkout to get $15 off and it would only be $194 Shipped //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
Here you go, this is a MUCH better amp, also a smexy amp as well //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif :Precision Power BK1800.1D Class D Amplifiers at Onlinecarstereo.com
Lol I was just going to tell him to buy that
My budget is around 200 dollars for an amp, i may be able to go over a little.
Op I'm telling you buy the bk1800.1d. I have it in my car with a 15" mojo and I'm doing 143's with it
Wow, the RE CTX amp and the Precision Power BK amp linked in this thread are both priced significantly less than I can buy them from my distributor. Yay for Internet ******.
Bet you if the amp blew 2 months after the warranty was up they wouldnt say "ill see what I can do" like you did for me. And yes that is a direct quote people
Audio Technix 1200 1 Amp Amplifier 1200W RMS 2400W Max Class D 1 Ohm Stable | eBay
clear out do to changing the companies name because of suit.
amazing amp that is rated at 12v's and clamp results of 1800rms at 1 ohm
Ct Sounds 1400 1D Amp Amplifier 1800W RMS 3000W Max Class D 1 Ohm Stable | eBay
same exact amp under new name //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
its a deal you cannot beat
does require 1/0 gauge wire //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
http://www.ebay.com/itm/Execution-Audio-Blue-1-0-AWG-0-ga-Gauge-Complete-Amp-Amplifier-Wire-Wiring-Kit-/111138341159?pt=US_Car_Audio_Video_Amplifier_Kits&hash=item19e05c8127
kit //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
llJohnnyll
llJohnnyll
Denver, Colorado
bgowdy
