which is the more solid choice?
bsean63
Undead Revolution
Kicker ZX1000.1
Amplifier Type 1 Channel
RMS Power: 500W x 1 @ 4 ohms THD at 4-Ohm RMS Power:
RMS Power: 1,000W x 1 @ 2 ohms
Speaker Level Inputs: Yes
Preamp Outputs: Yes
Built-In Crossovers: LP
Bass Boost: 0 - 18 dB
Frequency Response: 25-200Hz
Signal to Noise Ratio: 60 dB
Fuse Rating: n/a
Advanced chassis with extruded aluminum heatsink
Efficient class D circuitry
Top-mounted controls
KickBass 0-18 dB variable bass boost at 40 Hz
Variable 50-200 Hz low-pass crossover with 24 dB/octave slope
Defeatable 25 Hz subsonic filter
High level or low level inputs (125mV-10V)
PreAmp Signal Transfer (PAST) RCA outputs
Delayed turn-off logic circuit
Soft start turn-on circuit for reduced startup load
Short circuit, Over-voltage, Reverse polarity, Thermal overload (SORT) protection
Included remote KickBass control
Fully CEA-2006 compliant specifications for real-world power
or
Alpine Mrp-m1000
RMS Power Range : 600-1000 Watts
Number Of Channels: 1
Low Frequency response: 20 Hz
High Frequency Response: 200 Hz
Built In Crossovers: Yes
Channel Separation: Yes
Features
RMS Power @ 4 ohms: 600W x 1 (1% THD)
RMS Power @ 2 ohms: 1000W x 1
CEA-2006 Power Ratings @ 4 ohms: 600W x 1
Class-D (Digital) Amplifier Type
Continuously Adjustable Gain Control
Dual Sided Glass Epoxy PC Board
Gold Plated Input, Output, Power and Speaker Terminals
Gold Plated RCA Input Connectors
Adjustable Low-Pass Crossover
Top Mounted Blue LED Power Indicator
Over-Current, Over-Voltage and Thermal Protection
STAR Circuitry
MOSFET Power Supply Design
Thermal Management Control
Signal to Noise: 100dBA
Speaker Impedance: 4 or 2 Ohm
Frequency Response: 20 -200Hz (200Hz/-3dB)
Input Sensitivity: 0.2 - 4.0V
Power Requirements: 14.4V DC (11V to 16V)
bsean63
Undead Revolution
bsean63
ohio
Supergumby5000
michigan born
    May 14, 2026
michigan born
    May 14, 2026
