Which is the Better sub JL or Kicker Comp?
  • Thread starter Unregistered
  • Start date
  • Replies 11
  • Views 2K
U
Unregistered
Guest
What's up to all?
A quick question for you all. I'm looking for 2 new subs to be set up on independent sealed boxes, the smallest possible. So far I've narrowed it down to 2 subs Kicker Comp 10" or JL Audio 10WOs both 125w rms each 8ohms for 4ohm load.
Which would be best for my amp Sony 2150gsx 760w:
Key Features:
150 watts RMS x 2 at 4 ohms
190 watts x 2 at 2 ohms
380 watts x 1 in bridged mode
stereo, bridged mono, or Tri-Way output
MOSFET power supply and output stages
50-300 Hz high-pass/low-pass filter, 12 dB/octave
line-level and speaker-level inputs
gold-plated connectors
preamp outputs
variable bass boost (0-10 dB) centered at 40 Hz
requires 8-gauge power and ground leads
JL is a bettrt quality sp while kicker comp c is very cheap JL is VERY underrated
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif JL24 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
jl hands down... i run 2 10 wo's in my civic in a custom ported inclosure and they hit a consistent 147.3 they sound great in .8 sealed (minus woofer dis)
**** **** a **** JL kicker goes harder than anything.....it taked more power but if u aint got the money to be banging dont put **** in...so id have to say go with the comp vr's..and they bang hard as hell
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
7
4K
9512 lol If you're in that realm of woofers, there's quite a good selection outside of those 2, but DD is a very good pick IMO.
11
2.5 cubic feet per subwoofer not total. Those X's require some room.
7
804
Guest
GBallTors54
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
