Which is the Better sub JL or Kicker Comp?
  • Thread starter Unregistered
  • Start date
  • Replies 11
  • Views 2K
U
Unregistered
Guest
What's up to all?
A quick question for you all. I'm looking for 2 new subs to be set up on independent sealed boxes, the smallest possible. So far I've narrowed it down to 2 subs Kicker Comp 10" or JL Audio 10WOs both 125w rms each 8ohms for 4ohm load.
Which would be best for my amp Sony 2150gsx 760w:
Key Features:
150 watts RMS x 2 at 4 ohms
190 watts x 2 at 2 ohms
380 watts x 1 in bridged mode
stereo, bridged mono, or Tri-Way output
MOSFET power supply and output stages
50-300 Hz high-pass/low-pass filter, 12 dB/octave
line-level and speaker-level inputs
gold-plated connectors
preamp outputs
variable bass boost (0-10 dB) centered at 40 Hz
requires 8-gauge power and ground leads
JL is a bettrt quality sp while kicker comp c is very cheap JL is VERY underrated
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif JL24 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
jl hands down... i run 2 10 wo's in my civic in a custom ported inclosure and they hit a consistent 147.3 they sound great in .8 sealed (minus woofer dis)
**** **** a **** JL kicker goes harder than anything.....it taked more power but if u aint got the money to be banging dont put **** in...so id have to say go with the comp vr's..and they bang hard as hell
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
4K
9512 lol If you're in that realm of woofers, there's quite a good selection outside of those 2, but DD is a very good pick IMO.
2.5 cubic feet per subwoofer not total. Those X's require some room.
820
Guest
GBallTors54
