which is better
CalSpecBoy
For two 12'' Infinities??
Sub sepcs.
Power Handling, RMS: 300W
Power Handling, Peak: 1200W
Frequency Response (±3dB): 22Hz - 800Hz
Sensitivity: 92dB
Mounting Depth: 6-1/8"
Impedance: 4 Ohms
This one?
BOSS RIP-595
1,000 Watt 2 Channel Amp w/ VU Meters
RMS: 210 Watts per Channel @ 4 Ohms
Bridged Power @ 4 Ohms -1,000 watts
or this?
2 Channel Boss Klash K580
Max Power @ 2 Ohms – 450 watts x 2
RMS power @ 4 Ohms - 170 watts x 2 RMS
Bridged Power 900 watts x 1
would a Lanzar VIBE 258 be a good amp for my 2 12's?
2 x 400 Watts RMS at 4 Ohms
2 x 800 Watts Max at 4 Ohms
1 x 1600 Watts Max at 4 Ohms Bridged
2 x 650 Watts at 2 Ohms
Also take a look at Profile California CA1200.
http://www.etronics.com/product.asp?stk_code=proca1200&store=&catid=308
http://cgi.aol.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3069922446&category=18796
Im sure there are more places that sell them. They are very reliable amps and put out their rated power.
Also about what Playa1 said, the Vibe 258 wont put out the full 400 watts rms at 4 ohms but im sure it would do at least 300. My friend has one of these amps on his two Premier TSW125DVC's and those things wang like a mofo on it. The only thing about these amps is they dont really like high power hits like really low frequencies that require alot of power, his starts to clip slightly on the really low frequencies like around 30 hz and below but its still a good amplifier. For the price its a very good deal.
when ever they say bridged it refers to a 2 or multi channel amplifier, basically it means that you take the + from the 1st channel and the - from the 2nd channel ( usually on most amps)which increases the power. the reason being is that the frequencies produced by thoose 2 channels are used to power speakers like your tweets or mids and highs, but when you bridge the channels it becomes a mono amp which is meant for subwoofers which run at lower frequencies. hopefully that helped... Joe
CalSpecBoy
CalSpecBoy
Overland Park, KS
newt3no
