Which is a better amp.
scutzi128
Ok guys I have a set of Rainbow SLC 265s and I need an amp for them and I am down to 2 amps either a Kenwood Excelon KAC-X521, or a kenwood kac-7202. which amp would provide better sq as both produce around the same amount of power. Thanks guys any help would be great.
Neither....get a JL 300/4, and bridge it for 150wx2.
Or even better, keep the JL unbridged, and run the SLC's active //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Ditching the passive crossovers will make more of an SQ difference than swapping out comparable amplifier topologies any day...
I am not a huge JL guy, but the slash series amps work awesome on components. I have a 450/4 and there are not many to equal it. They are worth the money.
If you use he 300/2, then you will need to use the passive crossovers on the comps. The 300/4 will allow active control.
Both are good amps IMO.
please god not another one! please no more kenwood
I have never used active amplifying. I would not know what I am doing with it. Is it hard to learn how to set it up properly?
You can learn fairly easy. The 4 channel route makes the most sense as you can bridge for passive or you have the extra 2 channels to go active.
scutzi128
scutzi128
Pennsylvania
2Tone
vegang
vegang
