Which HU's play from memory?
I've never had a skipping problem with the Alpines I've used...are you going rockcrawling or something? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
nope, 2 AB 75.1 @ .7 ohms each and 2 DD 9515e at full tilt in an Xterra.
I'm pretty sure the stock unit will skip. I don't wanna spend money I don't have to, but I THINK some eclipse units are the only CD players that play through a memory buffer.
Nearly all HU's have built in memory for preventing skipping. Even the OEM decks we produce have memory built in. As for Hard Drives, they are more prone to skipping than a cd deck. The Hard drive is also more prone to failure from excess vibrations. If you want to ensure your deck won't skip, the best bet is a good install. First, ensure you have the rear support screw in the deck and making contact with the car frame. If possible, strap the HU down. Third, your HU operates better at a slight tilt. Normaly 5-10 degrees. Unfortunately, this is not always possible due to the dash.
I just thought of something. Have you looked at JVCs that play from SD cards like SHX750 or SHX850 i believe. If you want quality you might be able to play WAV or some kind of other loosless format, but look into that, cause i'm not sure how it works. But it deffinetely shouldn't skip, cause the SD card is a chip & not a hard drive.
update. I picked up a new, newly discontinued 8053 from cartoys for $288 total. //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif :peace:
I realize that all CD players played from a buffer, I just need a pretty large buffer.
djman37
SOLID
djman37
DFW, TX
bamaboy
