jchargu3
Which would I be better with (i think i asked before but i lost it)
INFO:
Sub amp is an Elemental Nine.1
Mid amp WILL BE an Elemental Nine.2 but im using my old sony until I get the Nine.2
Vehicle:
88 Chevy s10
Optima Yellow Top - dual post
OPTION A:
Nine.1 on its own 0 gauge line from battery
Nine.2 on its own 2 or 4 gauge line from battery
0 Gauge Side:
Battery Terminal to SINGLE fuse block with 150/180 amp fuse
From fuse block at battery direct to 9.1 amp using one single 0 to 4 gauge adapter direct into the amps Power
2 or 4 gauge side:
Battery Terminal to SINGLE fuse block with 150 amp fuse, from fuse block direct and input to nine.2 amp.
PROS
- Each amp has its own fuse, and its own lines complete
- If one fuse blows I still have the other range
- would only have to buy one 0 to 4 adapter
CONS
Very tight on the battery to add the 0 gauge to everything.
Still having two stereo power lines ran SOMEWHERE in the firewall
Option B:
Short 0 gauge provides power to a dual fuse box that has 2 4 gauge outputs
0 gauge
180 amp fuse From fuseblock to 4-0 adapter to the 9.1 amp, another 4-0 adapter into the amp
4 gauge
150 amp fuse from fuseblock to 9.2 amp.
PROS
- I free one port on the battery by removing the current 4 gauge to the smaller amp.
- One Fuse Block so little hassles to change fuses, or pull fuses when working on the system.
- Each amp has its own fuse incase one blows the other one wont
CONS
I would have to buy TWO 0-4 gauge adapters
Finding a place to put a big honkin dual fuse block.
Option C:
One wire into the truck, then split to two.
0 Gauge from battery to single fuse block, with a 300 amp fuse (i think?)
0 gauge from fuse block to inside distribution block 0 in 4ga out.
0 gauge from distribution block to ED nine.1 using the 0 to 4 ga adapters
4 gauge from distribution block to ED nine.2
PROS
-One wire into the truck, removes a wire from the battery terminal eliminating the 4 gauge thats already there.
-Less underhood wires.
CONS
-One fuse goes out, it all goes out.
-Having a dist block hidden in the interior
-having to use TWO 0 to 4 gauge adapters
Parts Breakdown on each option, expense wise
Option A:
Battery Terminal with a 0 gauge port, and a 4 gauge port
180 amp fuse
0 in 0 out fuse holder
0 to 4 ga adapter
Option B:
Battery Terminal with 0 gauge port and a 4 gauge port
1 - 0 Ga In, 2 - 4 ga out dual fuse block
180 amp fuse
150 amp fuse
2 - 0 to 4 ga adapter
Option C:
Battery Terminal with 0 gauge port and a 4 gauge port.
1 - 0 ga in and out fuse block
300 amp fuse
Distribution block 0 in, dual 4 out.
2 - 0 to 4 ga adapters
INFO:
Vehicle:
88 Chevy s10
OPTION A:
0 Gauge Side:
2 or 4 gauge side:
PROS
CONS
Option B:
0 gauge
4 gauge
PROS
CONS
Option C:
PROS
CONS
Option A:
180 amp fuse
0 to 4 ga adapter
Option B:
180 amp fuse
150 amp fuse
Option C:
300 amp fuse
