Which Cheap 4 channel
shortyg83
That infinity amp shares the same PCB with it's JBL cousin, IIRC (I know the 7541a does). Both are Harmon Kardon companies.
Scan around for the 7541a, you should be able to pick one up at a very enticing price from here, eBay, or leftover new stock or even a refurb with warranty.
The Infinity will do rated power (the Autotek is likely a little overrated) and I'm willing to bet the overall build quality of the Infinity is better. Not to mention I have a 7541a and 611a, so I can vouch for them. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Go with the 7540a then. Pretty much the same amp, just a different release year and naming convention.
I started to get one those jbl amp has a very good build quality, saw its guts on ampguts very well put together plus it look s good too, but I just couldn`t pass up a PPIDCX 1000.4 for 230.00 dollars and its power ratings are all 12.5 volts.
out of the three you put up there i would go with the eclipse anyday, plus it has a lot more adjustment etc., that may aid you in not having to buy a crossover.
jason
shortyg83
shortyg83
pa
JoeHemi57
vegang
vegang
