Which Battery?
BreakDaLaw
Cavalier Killer!
ok so im going to be powering my HK4000d and need to know which battery opition would you guys do.
2 Kintik HC800-$230
1 HC1400-$200
1 HC2400-$260
1 Deka 9A31-$170
Im thinking the 2400 would be all i needed...with big 3 and the 200a alternator to make this run good
me thinks you'll need more than 1 if u plan on pushing it....took 2 for me plus i was still dropping
its goning to be hard as hell to fit two dekas or kinteks in my car.... so what about doing like TI said and putting a 2400 in back and a 1400 in the front
you could get away with a single 2400 in the rear and not even have anything under the hood, but if you can afford both you will be in good shape with both. i have a stinger digital volt meter than is just a 3 wire hook up. i put it into my dash and hard wired it to my rear battery terminals
ok so im ive come up with two choices even though i know which one yall will choose...i will running either one(either the two dekas or the hc) for around 2-3 months untill i can save up enough to buy another one....
2 Dekas(maybe a smaller kintick later on)
or 1 HC2400 in the back (2nd one later on down the road)
just make sure when you bypass your front battery for now, you leave enough wire to cut/add two ring terminals where the 2nd battery is going to go. or do it now and just put something like a fuse block where the battery is going to be
BreakDaLaw
Cavalier Killer!
BreakDaLaw
Altavista
TIeclipseMOJO
Mike Mccabe
