Which amplifier to buy?
which means these functions?
The first claim is that the amplifier can work with 1ohm or 2ohm load. I don't know about others, but I still would not run this amplifier at 1ohm, unless I was on a camping trip and needed to fry some eggs. I would expect the amp to run very hot and less efficiently at 1ohm. This should be tried only with proper install, and/or additional forced cooling.
The second item is the Q-tune technology. It boosts the output near the high pass crossover frequency. It's most useful for tuning subwoofers in a sealed box. Think of a subwoofer that normally in a sealed box will experience a natural roll off at the deepest bass frequencies. If you would like to boost the response at lower frequencies, provided you have enough excursion and power headroom, you change the high pass (subsonic) to say 20Hz, and then boost the q-tune. So it's kind of like variable frequency bass boost which is a lot more useful than the standard useless bass boost on most amplifiers.
just a side note: The Boston sports a S/N Ratio of 100db vs the S/N Ratio of 85db on the Kappa. If you need a decent 4ch amp, get the Kappa. if you need a good 2 ch amp, get the Boston.
which means that The Boston sports a S/N Ratio of 100db vs the S/N Ratio of 85db on the Kappa?
need a good amp for SQ
and my budget is $ 250
to put the boston pro60
boston all the way.... ive seen inside those 4ch infinity amps..yuk.....single sided pcb board . jumpers everywhere....yuk.
the boston is better all the way around... ive also seen inside those amps to, and i like what i see ...//content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
thanks for asking this question for us. well I think For the 2 500 watt speakers you need a 1000 watt stereo amp that would give you 500 watts per speaker/side is best amplifier for you it's very lousy..
corobore
corobore
vv
canaliJohn
vegang
vegang
