charleslatrelle
Which amp to use I have two kicker cvr 12 4 ohm. I'm looking at NVX JAD1200.1 or RockfordFosgate prime R1200-1D
Try to get you anywhere from a 4 cubic ft to 5 cubes. And if you get the brutus wire them down to 1Ohm and give them the full 1200 rms with 0dbYea I have a decent size ported box
Lol im pretty sure the brutus can do 1200 clean at 1Ohm. I know a guy who was ******* 1400 out of one with an re xxx18then just pick your poison, either of your amp choices are fine, a soundqubed 1200.1D would do great along with an American Bass VFL4480.1D, both are in that price range too.
if you need a cheaper alternative, theres always hifonics, mbquart, ppi and RE audio budget powered amps, with these amps you'd normally want to shoot 400 rms over your desired rms figures, so aim for a 1600 watts rms amp if you going budget power.
Is it the 07 cvr kicker side ported box? if so that is only about 3.75 cubic feet which isn't too bad but you lose a lot of output since its a side tube port. I cant exactly remember how to go about the measurements I think its something like multiply length x width x height then divide it by 1728. But ask around on here you should be able to find someone who can make you 1.If you get a good enclosure you can give them subs more power and they will sound a hell of a lot better. Right now I'm runnin mine in a 4.7 cubic foot slot ported box at 1500 rms. By mine I mean 2 12" kicker CVRsI don't know how many cubic feet my box is how do I measure it and if not where a good place to find one cheap
I think you'll have a hard time backing up that claim w/concrete (or theoretical) evidence.you lose a lot of output since its a side tube port.
