which amp should i go will kenwood 600 watts or a visonik 1000 watts
  • Thread starter BOOM BOOM as the bass hits
  • Start date
  • Replies 1
  • Views 1K
  • 1
B
Guest
which one for these amps will give me the most watts and which one is better. im just starting my first system but it ant going to be my best...... lata in my life im going to buy a MTX RFL and get a RF db amp
for the amps id go with the visionik but dont waste your money on an rfl unless you plan on competing if you use them in your daily car yuoll be rebuildin them often. and from what ive heard they sound shitty too
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
Have you check to see if the prefab would fit...
13
For the sub you want to run.. The 700.1 will be more than enough power and enough Head room for that sub. For the Price? And the sub you are...
13
Your skar amp will catch on fire if you go full power?
I'll suggest a JP8 amplifier. I believe you can wire your sub to 2 ohm. It's Dual voice coil 4 ohm, correct? JP8 @ 2 ohm does 900 watts.
Guest
geonn
    May 12, 2024
Brendon Jenness
    May 11, 2024
