Which amp should i get
faygo187
I have 2 pioneer 12" tsw34c, and they do 150 rms 500 max and i aM LOOKING FOR A GOOD AMP FOR THEM.
i am thinking about the lanzar 1200 watt Vibe248 but i don't know if it will supply the power it says it will.
if any one knows about this amp or another good amp for theese 12" s under $250?
wtf, u just said it was 150 rms 500d is 500watts @ 1ohm, it is powerful enough to run like 3 of those subs...
600d is even more. WHAT MAKES U THINK U NEED A 2 CHANNEL AMP? YOU CAN USE A MONO (1 CHANNEL) AMP TO PUSH MORE THAN 1 SPEAKER........ AS A MATTER OF FACT I'D RECOMMED THA TU USE A MONO AMP TO PUSH SUBS ANYWAY
Yeah, mono only means one channel, but you could run 100 speakers off a mono amp. To put it the simplest way possible, they are good for running subs, that's all you really need to know at this point. If you have a mono amp that puts out 500 x 1 at 2 ohms, that means each of your subs will get 250 watts. Understand?
You use multiple channel amps if you're powering speakers. You know the difference between mono and stereo I hope. I don't think you'd want to be running your entire car stereo in mono. And yes a lot of people power their speakers off of amps, I plan on doing it as soon as I can... The HU just isn't big enough to generate enough power and keep it clean at the higher levels.
faygo187
faygo187
Charlotte, NC
Xander
