Which amp kit to buy? Please help
RoachForLife
So heres what Im powering, please let me know if the higher stuff is necessary
PDX 1.600 amp
PDX 4.100 amp
Powering 12" JL W6 and set of PG RSD6.5 comps.
Looking at sets from Kicker and JL Audio
Kicker PKD4 - $65shipped 4g main with 8g from dist block to amps. 8g ground
Kicker PKD1 - $130shipped 1g main with 4g from dist block to amps. 4g ground
JL XB-PCS4-2 - $100shipped 4g main (for all). 4g ground
Will I be okay with the cheapest one here? Id like a little wiggle room for the future, however one of my biggest concerns (not so much the price although saving $65 is nice) but that the 1g will be inflexible and hard to work with. Also (I realize this may be dumb) but I like the JL Audio flat red color of the power wire which goes better with my engine bay.
Anyhow, thoughts on this? Also any other comparable suggestions?
Thanks guys!
On a side note I need to get a set of RCAs for the speakers, suggestions/places to buy?
Hmm they dont seem to have a dual amp kit. So Id need a distribution block, suggestions?
Also I see you can select the fuse size, how do I go about selecting which fuse size?
Thanks
depending on the vehicle, 4 ga is more than enough, 4 gauge can handle 1000w at a 17 foot run, but 1/0 will give you ability to upgrade in the future. If you get a 4 ga kit get one from knukoncepts otherwise get the kicker 1/0
RoachForLife
RoachForLife
Florida
Rich B
michigan born
    May 14, 2026
michigan born
    May 14, 2026
