Which amp for Elemental Designs OV. 16?
Anything that will do around 700-1200 watts rms, depending on whether it's a sealed or ported box. If it's a ported box, the most important factor is knowing the tuned frequency, and setting the ssf (subsonic filter) correctly.
In a 1.6 cu ft sealed box, the 16Ov2 will handle 1200 rms all day, as long as the gains are set for no clipping. In a typical ported box, with ssf correcly set, I would be careful with anything over 900 rms.
It's a D4. Sorry if I sound like a complete noob, I've been out of audio for awhile.
So you want to look for an amp that will put out the above numbers into a 2 ohm load.
The Nine.1 will do 950-1000 rms easily into a 2 ohm load. Any other amp in that neighborhood of output will do just fine //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
bimmer540i
bimmer540i
Carrollton, GA
bimmer540i
BP1Fanatic
BP1Fanatic
