which 6.5 comps for this amp?
BTW I'll check the prices on 1/0 gauge and see if I can afford it, after buying those 3 things I'm pretty much broke right now :p
Check ebay for Kicker PKD1 wiring kits. It's a dual-amp kit, it includes 1/0 gauge wire, a distro block, and some 4 gauge wire to go to the amps from the distro block. Plus a few extra goodies, too. It can be had for around $90 shipped, I believe.
Ok, Here I come again...
I just receive the Hifonics and I noticed that it has 4 teminals (-)(-)(+)(+) but it's single channel right? if I'm plugging my CVR's at 1 ohm which their DVC are already in parallel, should I merge both wires and use a single (+) (-) from the amp? or is it true that it's internally bridged and it has two set of terminals for convenience to avoid merging the subs cables and then I'm able to connect each sub to it's own terminal and still be 1 ohm? My purpose is to give them 600w RMS.
Ok about the cables now, I'm pretty much done buying stuff, I just need to buy the power wires and distro block, the kicker kit you suggest before contents:
20 ft. - 1/2 AWG Power Cable (is this one ok? I though you suggest 1/0)
3 ft. - 1/0 AWG Ground Cable (here I got lost why ground is diff?)
5 ft. - 4 AWG extra Power Cable (is this ok to run from distro to amps?)
5 ft. - 4 AWG extra Ground Cable (I think this is also for the amp to distro)
2 Power Distribution Blocks (DB 1448)
Fuse Holder (FHMA)
300A ANL Fuse (what is this fuse for? the one for batt terminal? too big right? you suggest 125A)
Ok, Thanks for the help
Try to find a Class D mono amp that is 1 ohm stable at around 600-800w rms for those subs. (each wired in parallel = 2 ohms each, then both wired in parallel = 1 ohm at the amp)
Something like a Hifonics BXi606D or similar.
after some searching I think I understand pretty much everything on the cables, I dont want to start a new thread for this question, I know I've been off the main topic but I hope you can help me with this one.
I'm confused about wiring the CVR's at 1 ohm, according to your saying I believe they should be wiring in one of these ways, but I'm not sure which is the correct one:
Besides I found this equation diagram on the forum which I think (if I'm doing the math ok) the setup in any of these ways will be 4 ohm
Can someone clear up this for me please?
Thank you!
It really doesn't matter much.
However, I say middle diagram. But use the left + and - for one sub and the right + and - for the other.
L+ R+ L- R-
Ok! I Got it! so, this will be 1 ohm as you said before? I just want to get the best performance out of my new setup, and I believe that's 600w rms @ 1ohm correct?
rmdl51
White_Shadow
rmdl51
Fullerton CA
DejaWiz
michigan born
    May 14, 2026
michigan born
    May 14, 2026
