Which 10" Woofer?
Virindok
PA
I am looking for a good 10" SQ woofer that can hit low and still get loud.
Right now I am trying to decide between
RE 10" SRX10D4
* Electrical Q Value -Qes: 0.39
* Mechanical Q Value -Qms: 5.5
* Total Speaker Q Value -Qts: 0.36
* Free Air Resonance -Fs: 25.3 Hz
* Equivalent Compliance -Vas: 31 liters
* One-Way, Linear Excursion -Xmax: 18 mm
* Efficiency -SPL 1W/1m: 85.3 dB SPL
* Effective Piston Area -Sd: 310 cm^2
* DC Resistance -Re: 1.8 ohm
* Nominal Impedance -Znom: Dual 4 ohm
* Thermal Power Handling -Pe: 300 W
* Force Factor -Bl: 14.35
http://www.woofersetc.com/p8396/SRX10D4--RE-Audio-10"-SRX-Series-Dual-4-Ohm-Subwoofer.htm
Memphis 10" MCP10D4
# RMS/Peak: 300w/600w
# Sensitivity: 86 dB
# Magnet Size: 65 oz
# Mounting Depth: 5"
MCP10D4 - Memphis 10" DVC 4 Ohm Mclass Subwoofer
Memphis 10" M3104D
# RMS/Peak (W) 300/600
# Sensitivity (dB) 91.3
# Magnet SIze (oz) 85
# Mounting Depth (in) 5.6
15-M3104D - Memphis 10" 600 Watt DVC Subwoofer
Memphis 10" C310D4
* Size: 10" Inches
* RMS Peak: 400/800
* Sensitivity: 85dB
* Magnet Size: 82 oz
* Mounting Depth: 6.06" Inches
15-C310D4 - Memphis 10" Dual 4 Ohm M3 Series Subwoofer
or a JL 10" 10w3v3 2 ohm
# Peak Power Handling: 1000 Watts
# RMS Power Range : 75-500 Watts
# Impedance: 2 Ohm
# Diameter: 10 Inch
# Sensitivity: 84.87 dB
10W3V3-2 - JL Audio 10" 500 Watt 2 Ohm Subwoofer
Any other recommendations are welcome as well.
The reason that 3 of those subs are Memphis is because I used to run two 15" memphis power reference series subs and I loved them - and that's pretty much the lowest series of memphis subs.
Also, I am still deciding between ported or sealed but my primary concern is hitting the low notes so I'll prolly end up building a low tuned ported box.
Not looking to spend more than $300 for the sub.
Thanks for any suggestions!
ill throw my vote in for the JL W3v3. I just put one in my car 12" in a ported box. I cant believe how nice it sounds off the 500.1 amp. Sounds like the w6v2 i had last year. Couldnt be more pleased.
The C3104D is a beefy new version of the M3104D (discontinued the M3). The M3 and C3 series are 2 steps above the Power Reference series. Both are good subs. You can also take a look at the Kicker Solobaric L7. I would go with the M3, C3, or L7.
Street Edge, Power Reference, M-Class, M3, C3, Mojo
& now I believe Memphis even carries a shallow mount sub.
Virindok
Virindok
PA
denim
