Where to run 1/0 wire...
TheBigDu
Hey guys,
I've done several installs, so I'm not a total newb to running power wire to the trunk, but my question may seem stupid.
In the past, I've only dealt with wire up to 4 AWG. Since the wire wasn't extremely large, I could run it undereneath the doorsill molding. But now I'm upgrading to 1/0 in my car, and I think it's going to be too tight to run it in the same location.
From seeing others' installs, I think I'm supposed to pull back the edge of the carpet along the doors and slide the wire down under the carpet. Is this correct? And if so, I don't have to remove the front seat bolts to do so, do I? Just for reference, I have an '02 Maxima.
Thanks in advance!
YUou're lucky. Even with 4awg, I have to remove the seats and all plastic moldings to run it under the carpet because the doorsils are full of crapola. I got pissed the other night and now the Tahoe is carpetless :O
That sucks, man. Good luck with putting it all back together.
Thanks for the help; I guess I'm just going to try with the carpet only first and try to avoid pulling the seats out.
Hey man... don't feel so bad. Just look @ it as an oppourtunity to add sound deadener. =D
i just did my 2000 impala with 0 gauge and i took off all of the plastic panels along one side then that whole edge of carpet basically moved freely, i movedthe carpet away from the floor where it was molded and slid the cable down as everyone said. the plastics went back on as easy as they came off. i would give this method a try and you should be fine
could always run it under ur car like i did with my 2 runs, and just have it come through a hole in the trunk floor //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
TheBigDu
TheBigDu
West New York, NJ
azbass
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
