where to get alternator for an s600?
The alternator in my 99' BMW 540i6 is also water cooled and the car is also packed with electronics from the factory as well. Mine is rated at 160a IIRC and I've added about 2000wrms worth of amplifers to it not including the the extra electronic gear and I don't have any charging issues. I did change out the factory battery with a Deka Intimadator though......
The factory battery cables both power and ground are 1/0 from the factory....//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif:D:D
P.S. check out H.O. Alternators, when I thought about buying an high output alt, they sent me a quote for one but I don't know if they knew it was water cooled though....
150 amps... but there is ALOT of electronics in it..
There is but most of them dont draw that much, you could probably be fine depending on your amps. I reccomend seeing if any other models or years share the same mounting, you might be able to find one that puts out a bit more on a newer model.
The alternator in my 99' BMW 540i6 is also water cooled and the car is also packed with electronics from the factory as well. Mine is rated at 160a IIRC and I've added about 2000wrms worth of amplifers to it not including the the extra electronic gear and I don't have any charging issues. I did change out the factory battery with a Deka Intimiadator though......The factory battery cables both power and ground are 1/0 from the factory....//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif:D:D
hmm.. really? odd that your 5 series has a 160, and the 600 only has 150.. good on beemer!
I'm not 100% sure but I'll about 95% that it's somewhere between 150-160a though......//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif:D:D
02parkave
Banned
02parkave
Oklahoma City, Oklahoma
1baller
